Hello
Is it possible to restart one display from CMS?
Thank you
Hello
Thank you
Roneza,
Currently it is not directly possible from the CMS. There was a few questions about this before, although I don’t seem to be able to find where this was asked before. There are ways to do a reboot remotely, but it depends on the type of client you are running and using something like the “Shell Command” option in a layout. From there scheduling the layout to run for a minute with the priority setting.
I would suggest testing out any solution on a test display, as you might cause the client to reboot continuously.
EDIT: I did find this feature request, but I remember a few other post about this somewhere.
