Reporting proof of play comes out nothing when click submit
hi my xibo reporting proof of play is blank while already selected some display/player. please help.
Have you enabled stats reporting and set the Aggregation level on the Display Profile Setting?
Players will only aggregate completed records, with the collection made at the end. For example, if a Widget had a duration of 1 hour, the stat would be recorded once the Widget has expired (after the hour duration).
