【report】Xibo Player Installation
Hello everyone.
I was unable to install the player,
but I have solved the problem and will share it with you.
Installer Version
Xibo for Windows v4 R404
setup ended wit an error:
setup ended prematurely because of an error
Cause of the Problem
I was using multibyte space in my Windows account name.
Example: 太郎 田中 (using multibyte space between “太郎” and “田中”)
I re-created a new account that did not use the new multibyte space and re-installed it again and it installed successfully.
The multibyte username itself is fine,
but the multibyte spaces were not.
I hope this helps.Thanks.
