How can I have a remote dataset Overwrite existing data each time it syncs?
Currently I get a new row in the dataset with each change of data.
Thank you !
Thank you !
Hi Peter, Thanks for the reply.
Yes I have Truncate set to Always … but I still get a new row with every data change.
Have tried creating multiple datasets with different sources and settings and still get the same behaviour.
v1.8.7 - Docker.
It seems that there is an issue with truncating the dataSet data in the task that does fetch the data from remote source - I’ve created the github issue for it with the fix as well.
