Remote dataset no columm value
i have in Xibo an remote datset. this dataset should get the birthdate of employee’s, and push that to a layout.
when i go to edit the dataset to test the data, i get the following result:
   "entries": [
         "lastUpdated": "2024-09-30 09:31:07",
         "employees": [
               "fullName": "employee name",
               "firstName": "employee first name",
               "lastName": "employee last name",
               "avatar": "https://storage.googleapis.com/shiftbase-avatars/avatars/user-picture_150x200.png"
   "number": 2,
   "isEligibleToTruncate": true,
   "processed": [
   "messages": [
      "Processing 1 results into 1 potential columns",
      "Processing Result with Data Root employees",
      "DataRoot is an array",
      "Processing 0",
      "Processing 1",
      "Consolidating entries",
      "There are 2 entries in total"
now when i view the data within the dataset, it says that the collum is empty.
can anyone please help me?
The column type is set to remote?
Jupp, these are my columm settings.
The remote data path should be the JSON path, not the url.
also does not work.
i tried copying settings from a remote dataset that works, tried every logical JSON path, but it still does not work.
or it could be possible that i dont exactly know what they mean with JSON path.
Dataroot is where you want xibo to start getting the data,
So if you have :
“firstName”: “John”,
“lastName”: “doe”,
“age”: 26,
“address”: {
“streetAddress”: “naist street”,
“city”: “Nara”,
“postalCode”: “630-0192”
“phoneNumbers”: [
“type”: “iPhone”,
“number”: “0123-4567-8888”
“type”: “home”,
“number”: “0123-4567-8910”
Your JSON path to get iPhone is:
$.phoneNumbers[:1].type
To the path for home is:
$.phoneNumbers[:2].type
The path for all instances of type
$.phoneNumbers[:].type
What xibo wants to know is what column to match up with what variable(s) in your list.
This eg might be different for what you are trying to achieve but the JSON path is similar to your select xmlnode but the idea is to pick your dataroot, assgn the columns path value accordingly
