Remote dataset does not parse date fields
I have this json:
    "data": [
            "id": 1,
            "date": "2018-10-10 13:11:21",
            "title": "Test 1"
            "id": 2,
            "date": "2018-10-11 03:04:41",
            "title": "Test 2"
            "id": 3,
            "date": "2018-10-12 06:51:21",
            "title": "Test 3"
And I set date column like this:
But when I try to test data I get mydate field set to null:
    "entries": [
            "data": [
                    "id": 1,
                    "date": "2018-10-10 13:16:08",
                    "title": "Test 1"
                    "id": 2,
                    "date": "11/10/2018 03:09:28",
                    "title": "Test 2"
                    "id": 3,
                    "date": "2018-10-12 06:56:08",
                    "title": "Test 3"
    "number": 1,
    "processed": [
                "myid": 1,
                "mydate": null,
                "mytitle": "Test 1"
                "myid": 2,
                "mydate": null,
                "mytitle": "Test 2"
                "myid": 3,
                "mydate": null,
                "mytitle": "Test 3"
    "messages": [
        "Processing 1 results into 3 potential columns",
        "Processing Result with Data Root data",
        "DataRoot is an array",
        "Processing 0",
        "Processing 1",
        "Processing 2",
        "Consolidating entries",
        "There are 3 entries in total"
I tried to change the format of the dates but I get always null
I find the problem:
in DataSetFactory.php I change the line
case 3:
     // This expects an ISO date
     $result[$column->heading] = $this->getSanitizer()->getDate($value[1]);
with
case 3:
    $result[$column->heading] = $this->getSanitizer()->getDate($value[0],null,$entry);
And then everything works as expected
