As in the manual I configured a remote dataset. When testing data I get a respons.
Now for step two: Configure Columns. In the manual it suggests that three TYPE of column should appear: Value, Fomula and Remote. Remote doesn’t appear.
This happens editing the first (excisting) columns “Col1” and when I try to create a new one.
Working on CMS version 2.0.1, Win10-64 and Docker 17.09.
I can’t replicate that here. All I can suggest is upgrading to 2.0.3 initially, then make a new dataset, ensure Remote is ticked, and then try again with that.
