hey, very new to xibo, a contracter came in and installed 1.7.8 for us to use, having issues with displaying regions on our displays, here is the log from when i booted up our display just then, can anyone assist me? any help would be great.
292 2017-03-31 10:01:55 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
293 2017-03-31 10:01:55 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to /var/xibostore/\6.xlf failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
294 2017-03-31 10:02:05 Client [UI Thread] Region - Eval Options Unable to start new image object: Value ‘-727380968’ is not a valid value for Interval. Interval must be greater than 0.Parameter name: Interval
295 2017-03-31 10:02:05 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
296 2017-03-31 10:02:05 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to /var/xibostore/\6.xlf failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
297 2017-03-31 10:02:15 Client [UI Thread] Region - Eval Options Unable to start new image object: Value ‘-727380968’ is not a valid value for Interval. Interval must be greater than 0.Parameter name: Interval
298 2017-03-31 10:02:15 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
299 2017-03-31 10:02:15 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to /var/xibostore/\6.xlf failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
300 2017-03-31 10:02:25 Client [UI Thread] Region - Eval Options Unable to start new image object: Value ‘-727380968’ is not a valid value for Interval. Interval must be greater than 0.Parameter name: Interval
301 2017-03-31 10:02:25 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
302 2017-03-31 10:02:25 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to /var/xibostore/\6.xlf failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
303 2017-03-31 10:02:35 Client [UI Thread] Region - Eval Options Unable to start new image object: Value ‘-727380968’ is not a valid value for Interval. Interval must be greater than 0.Parameter name: Interval
304 2017-03-31 10:02:35 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
305 2017-03-31 10:02:35 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to /var/xibostore/\6.xlf failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
306 2017-03-31 10:02:45 Client [UI Thread] Region - Eval Options Unable to start new image object: Value ‘-727380968’ is not a valid value for Interval. Interval must be greater than 0.Parameter name: Interval
307 2017-03-31 10:02:45 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
308 2017-03-31 10:02:45 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to /var/xibostore/\6.xlf failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
309 2017-03-31 10:02:55 Client [UI Thread] Region - Eval Options Unable to start new image object: Value ‘-727380968’ is not a valid value for Interval. Interval must be greater than 0.Parameter name: Interval
310 2017-03-31 10:02:55 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
311 2017-03-31 10:02:55 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to /var/xibostore/\6.xlf failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
312 2017-03-31 10:03:05 Client [UI Thread] Region - Eval Options Unable to start new image object: Value ‘-727380968’ is not a valid value for Interval. Interval must be greater than 0.Parameter name: Interval
313 2017-03-31 10:03:05 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
314 2017-03-31 10:03:05 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to /var/xibostore/\6.xlf failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
315 2017-03-31 10:03:15 Client [UI Thread] Region - Eval Options Unable to start new image object: Value ‘-727380968’ is not a valid value for Interval. Interval must be greater than 0.Parameter name: Interval
316 2017-03-31 10:03:15 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
317 2017-03-31 10:03:15 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to /var/xibostore/\6.xlf failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
318 2017-03-31 10:03:25 Client [UI Thread] Region - Eval Options Unable to start new image object: Value ‘-727380968’ is not a valid value for Interval. Interval must be greater than 0.Parameter name: Interval
319 2017-03-31 10:03:25 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
320 2017-03-31 10:03:25 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to /var/xibostore/\6.xlf failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
321 2017-03-31 10:03:35 Client [UI Thread] Region - Eval Options Unable to start new image object: Value ‘-727380968’ is not a valid value for Interval. Interval must be greater than 0.Parameter name: Interval
322 2017-03-31 10:03:35 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
323 2017-03-31 10:03:35 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to /var/xibostore/\6.xlf failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
324 2017-03-31 10:03:45 Client [UI Thread] Region - Eval Options Unable to start new image object: Value ‘-727380968’ is not a valid value for Interval. Interval must be greater than 0.Parameter name: Interval
325 2017-03-31 10:03:45 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
326 2017-03-31 10:03:45 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to /var/xibostore/\6.xlf failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
327 2017-03-31 10:03:55 Client [UI Thread] Region - Eval Options Unable to start new image object: Value ‘-727380968’ is not a valid value for Interval. Interval must be greater than 0.Parameter name: Interval
328 2017-03-31 10:03:55 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
329 2017-03-31 10:03:55 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to /var/xibostore/\6.xlf failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
330 2017-03-31 10:04:05 Client [UI Thread] Region - Eval Options Unable to start new image object: Value ‘-727380968’ is not a valid value for Interval. Interval must be greater than 0.Parameter name: Interval
331 2017-03-31 10:04:05 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
332 2017-03-31 10:04:05 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to /var/xibostore/\6.xlf failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
333 2017-03-31 10:04:15 Client [UI Thread] Region - Eval Options Unable to start new image object: Value ‘-727380968’ is not a valid value for Interval. Interval must be greater than 0.Parameter name: Interval
334 2017-03-31 10:04:15 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
335 2017-03-31 10:04:15 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to /var/xibostore/\6.xlf failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
336 2017-03-31 10:04:25 Client [UI Thread] Region - Eval Options Unable to start new image object: Value ‘-727380968’ is not a valid value for Interval. Interval must be greater than 0.Parameter name: Interval
337 2017-03-31 10:04:25 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
338 2017-03-31 10:04:25 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to /var/xibostore/\6.xlf failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
339 2017-03-31 10:04:35 Client [UI Thread] Region - Eval Options Unable to start new image object: Value ‘-727380968’ is not a valid value for Interval. Interval must be greater than 0.Parameter name: Interval
340 2017-03-31 10:04:35 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
341 2017-03-31 10:04:35 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to /var/xibostore/\6.xlf failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
342 2017-03-31 10:04:45 Client [UI Thread] Region - Eval Options Unable to start new image object: Value ‘-727380968’ is not a valid value for Interval. Interval must be greater than 0.Parameter name: Interval
343 2017-03-31 10:04:45 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
344 2017-03-31 10:04:45 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to /var/xibostore/\6.xlf failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
345 2017-03-31 10:04:56 Client [UI Thread] Region - Eval Options Unable to start new image object: Value ‘-727380968’ is not a valid value for Interval. Interval must be greater than 0.Parameter name: Interval
346 2017-03-31 10:04:56 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
347 2017-03-31 10:04:56 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to /var/xibostore/\6.xlf failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
348 2017-03-31 10:05:06 Client [UI Thread] Region - Eval Options Unable to start new image object: Value ‘-727380968’ is not a valid value for Interval. Interval must be greater than 0.Parameter name: Interval
349 2017-03-31 10:05:06 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
350 2017-03-31 10:05:06 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to /var/xibostore/\6.xlf failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
351 2017-03-31 10:05:16 Client [UI Thread] Region - Eval Options Unable to start new image object: Value ‘-727380968’ is not a valid value for Interval. Interval must be greater than 0.Parameter name: Interval
352 2017-03-31 10:05:16 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
353 2017-03-31 10:05:16 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to /var/xibostore/\6.xlf failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
354 2017-03-31 10:05:26 Client [UI Thread] Region - Eval Options Unable to start new image object: Value ‘-727380968’ is not a valid value for Interval. Interval must be greater than 0.Parameter name: Interval
355 2017-03-31 10:05:26 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
356 2017-03-31 10:05:26 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to /var/xibostore/\6.xlf failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
357 2017-03-31 10:05:36 Client [UI Thread] Region - Eval Options Unable to start new image object: Value ‘-727380968’ is not a valid value for Interval. Interval must be greater than 0.Parameter name: Interval
358 2017-03-31 10:05:36 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
359 2017-03-31 10:05:36 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to /var/xibostore/\6.xlf failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
360 2017-03-31 10:05:46 Client [UI Thread] Region - Eval Options Unable to start new image object: Value ‘-727380968’ is not a valid value for Interval. Interval must be greater than 0.Parameter name: Interval
361 2017-03-31 10:05:46 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
362 2017-03-31 10:05:46 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to /var/xibostore/\6.xlf failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
363 2017-03-31 10:05:56 Client [UI Thread] Region - Eval Options Unable to start new image object: Value ‘-727380968’ is not a valid value for Interval. Interval must be greater than 0.Parameter name: Interval
364 2017-03-31 10:05:56 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
365 2017-03-31 10:05:56 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to /var/xibostore/\6.xlf failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
366 2017-03-31 10:06:06 Client [UI Thread] Region - Eval Options Unable to start new image object: Value ‘-727380968’ is not a valid value for Interval. Interval must be greater than 0.Parameter name: Interval
367 2017-03-31 10:06:06 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
368 2017-03-31 10:06:06 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to /var/xibostore/\6.xlf failed. Exception raised was: Specified argument was out of the range of valid values.Parameter name: Unable to set and start a media node
369 2017-03-31 10:06:16 Client [UI Thread] Region - Eval Options Unable to start new image object: Value ‘-727380968’ is not a valid value for Interval. Interval must be greater than 0.Parameter name: Interval
