we are looking for suitable clients which can support a 3840x2160 resolution.
The client should be very small, so we can hide it under the public display. Ideally would be one of this hdmi-dongle pc’s, so we don’t have to worry about the assembling of the client under the display.
We already informed us about the second generation of the Intel Compute Stick (STK2m3W64CC), are there any xibo-users who can recommend this stick?
Maybe there exists some possible android clients, which match our requirements?
According to my experiences of doing lot of 4K walls,
a 4K image which is 3840x2160 will also require performance form the system and therefor,
I do recommend AOpen DE6140 with 8GB RAM, SSD Drive and the faster AMD CPU (there are two types offered for this particular device)
