Recommendation: Reduce log level of empty result set
Hey @dan and @alex,
We have a DataSet that, by design, returns empty overnight and sometimes all day depending on current happenings. Each time an empty data set is retrieved, an error like the following is logged:
Request failed for dataSet id XX. Widget=XXX. Due to Empty Result Set with filter criteria.
This results in thousands of useless log entries across our multiple displays.
May I kindly suggest this log be reduced from ERROR to either INFO or NOTICE since an empty set is not always the undesired behavior, and thusly not an error?
Thank you for your consideration.
That’s certainly something we can consider, I’ve created an issue for it here - https://github.com/xibosignage/xibo/issues/1580
Thanks for hearing me out!
Brodkin CyberArts
http://brodkinca.com | 310.220.0590
DESIGN. DEVELOPMENT. CONSULTING.
Information contained in this email or any attachment may be of a confidential nature which should not be disclosed to, copied or used by anyone other than the addressee. If you receive this email in error, please delete the email from your computer. Do not post anything in this email to any online forum without express permission of the sender. No pixels were harmed in the making of this disclaimer.
We will change it to info, that will be live in 1.8.11.
You’re fantastic!
Brodkin CyberArts
