Radio streaming/ background music
Is there any simple way how you can stream an online radio on xibo ?
If it’s on a website that your player can access I don’t see why not.
Or if they provide an embed code, then that should work as well.
What if it’s distributed as a Shoutcast / Icecast stream? HTTP:8000 port usually.
HI there Roberg,
There are several player generators out there. I’ve used this one a few times since it is basically plug and play. In my case I just embed the code in a super small 1x1 region at the bottom left side of the screen. Best of luck.
Hi All. Thanks for your reply.
