could anyone tell me what suppose i make now , when i press on the xibo player watchdog thats whats apper down right blow of the screan so is anyone had idea about it .and thanks for eavryone
my greetings hayder
Is the user running the Xibo client an administrator?
and when i wanna show it on the display just tell me thats there is an error in !!
Are you certain that it’s correct path to local library?
by default it should be C:\Users\USERNAME\Documents\Xibo Library
In CMS settings you will need fully qualified path to CMS library as well
Player and CMS library must be separate.
As for your last screenshot, at what page do you see that?
Did you make any changes to your CMS?
well I kept everything default and this on appalications page .
