Docker CMS version 2.3.6
Android player
none yet
Hello all,
new to Xibo, i was looking for a solution of Digital Signage to install to the fast-food of my parents where we had a cloud-based solution that went out of business recently. We have a setup made out of 6 screens where 5 displays a menu, one some pictures, advertisement, it is mainly a slideshow let’s say. An additional screen is placed above our ice-cream fridge, for the ice-cream menu itself. I already setup a docker CMS installation that is running, i started to create some templates and play with the software, so far so good. What i wanted to know is the best practice to achieve what i want which consist in the same background picture for the 5 screens with the menu, and only the content will vary. There are the example images :
edit : i can only put one image, the first one would be the same but empty from any texts.
I already created the model using a template with the empty background image, so i can reuse it for all the screens. Now about the data texts, i assume i need to create some datasets, but that’s where i am not sure about the way to proceed, as each screen is having a different amount of plates per category.
Last question about the Android p^layer licenses, should i buy it for each device controlling a screen ? Can i do that with the same Google account, or do i need to setup different one ?
Thanks for the help.
