i am using version Version 1.8.12 of xibo and i have some troubles with the chart module. I can not set a custom filter query. Everytime i enter something and click “save” theres no error. But when i then open the preference tab the filter text fields is empty again. Using the normal filter works fine.
Is this a known issue ?
troubleshoot log:
For testing i have two columns (eins,zwei) and i want to add the filter eins=zwei
71101,deaa740,“2019-06-27 11:54:38”,WEB,/playlist/widget/329,PUT,“Saving Widget chart on PlaylistId 243 WidgetId: 329”,DEBUG
71102,deaa740,“2019-06-27 11:54:38”,WEB,/playlist/widget/329,PUT,"Saving attrib WidgetOption backgroundColor with value ",DEBUG
71103,deaa740,“2019-06-27 11:54:38”,WEB,/playlist/widget/329,PUT,“Saving attrib WidgetOption config with value [{“columnType”:“x-axis”,“dataSetColumnId”:“30”},{“columnType”:“y-axis”,“dataSetColumnId”:“2”}]”,DEBUG
71104,deaa740,“2019-06-27 11:54:39”,WEB,/playlist/widget/329,PUT,“Saving attrib WidgetOption dataSetId with value 1”,DEBUG
71105,deaa740,“2019-06-27 11:54:39”,WEB,/playlist/widget/329,PUT,“Saving attrib WidgetOption filterClauses with value [{“filterClause”:“eins”,“filterClauseOperator”:“AND”,“filterClauseCriteria”:“equals”,“filterClauseValue”:“zwei”}]”,DEBUG
71106,deaa740,“2019-06-27 11:54:39”,WEB,/playlist/widget/329,PUT,“Saving attrib WidgetOption fontColor with value #000000”,DEBUG
71107,deaa740,“2019-06-27 11:54:39”,WEB,/playlist/widget/329,PUT,"Saving attrib WidgetOption fontSize with value ",DEBUG
71108,deaa740,“2019-06-27 11:54:39”,WEB,/playlist/widget/329,PUT,“Saving attrib WidgetOption graphType with value line”,DEBUG
71109,deaa740,“2019-06-27 11:54:39”,WEB,/playlist/widget/329,PUT,“Saving attrib WidgetOption legendPosition with value top”,DEBUG
71110,deaa740,“2019-06-27 11:54:39”,WEB,/playlist/widget/329,PUT,"Saving attrib WidgetOption name with value ",DEBUG
71111,deaa740,“2019-06-27 11:54:39”,WEB,/playlist/widget/329,PUT,“Saving attrib WidgetOption orderClauses with value []”,DEBUG
71112,deaa740,“2019-06-27 11:54:39”,WEB,/playlist/widget/329,PUT,“Saving attrib WidgetOption seriesColors with value []”,DEBUG
71113,deaa740,“2019-06-27 11:54:40”,WEB,/playlist/widget/329,PUT,“Saving attrib WidgetOption showLegend with value 0”,DEBUG
71114,deaa740,“2019-06-27 11:54:40”,WEB,/playlist/widget/329,PUT,“Saving attrib WidgetOption startYAtZero with value 0”,DEBUG
71115,deaa740,“2019-06-27 11:54:40”,WEB,/playlist/widget/329,PUT,"Saving attrib WidgetOption title with value ",DEBUG
71116,deaa740,“2019-06-27 11:54:40”,WEB,/playlist/widget/329,PUT,“Saving attrib WidgetOption updateInterval with value 5”,DEBUG
71117,deaa740,“2019-06-27 11:54:40”,WEB,/playlist/widget/329,PUT,“Saving attrib WidgetOption useFilteringClause with value 1”,DEBUG
71118,deaa740,“2019-06-27 11:54:40”,WEB,/playlist/widget/329,PUT,“Saving attrib WidgetOption useOrderingClause with value 0”,DEBUG
71119,deaa740,“2019-06-27 11:54:40”,WEB,/playlist/widget/329,PUT,"Saving attrib WidgetOption x-axis-label with value ",DEBUG
71120,deaa740,“2019-06-27 11:54:40”,WEB,/playlist/widget/329,PUT,"Saving attrib WidgetOption y-axis-label with value ",DEBUG
71121,deaa740,“2019-06-27 11:54:40”,WEB,/playlist/widget/329,PUT,“Linking 0 new media to Widget 329”,DEBUG
71122,deaa740,“2019-06-27 11:54:40”,WEB,/playlist/widget/329,PUT,“Unlinking 0 old media from Widget 329”,DEBUG
71123,deaa740,“2019-06-27 11:54:40”,WEB,/playlist/widget/329,PUT,"Notifying upstream playlist. Notify Layout: 1 Notify Displays: ",DEBUG
71124,deaa740,“2019-06-27 11:54:40”,WEB,/playlist/widget/329,PUT,“Audit Trail message recorded for Widget with id 329. Message: Saved”,DEBUG
71125,deaa740,“2019-06-27 11:54:40”,WEB,/playlist/widget/329,PUT,“Media assigned: 0”,DEBUG
71126,deaa740,“2019-06-27 11:54:40”,WEB,/playlist/widget/329,PUT,"Request stats: {
“default”: {
“select”: 11,
“update”: 2,
“insert”: 19,
