Hi Peter,
thanks for response, this is indeed very serious issue which is visible in both Chrome and also the Firefox.
I am using the latest versions of these browsers. CMS version is 1.8.11
It is very simple and easy to duplicate this by,
Click “Schedule”
Select a display of your choice from the display list
Click “Add event”
Define start and end date
Click to select from “Layout/Campaign”, you will than see the problem.
Hi Peter,
browser resolution is not always the same depending on where it is used.
I suppose the page should work according to the resolution given by the device where CMS is used without setting any conditions such as the resolution must be full hd or hd ready or anything else.
What i am chasing of,
isn’t page suppose to be responsive?
IMO, it doesn’t seem to be responsive, if i increase and decrease the size of my browser window, the page is not behaving accordingly, so it is not responsive.
I am very surprised if nobody has noticed this issue.
