When I create a clock in a region on my layout, it does not show the correct date. The time of the clock in the layout is correct, and the schedule correctly identifies the date and time. I have set my time zone (America/Chicago) and the latitude and longitude of the building we are using Xibo in. I still cannot get the date to display correctly. It is showing April 6th, when it should be showing August 4th.
Another issue I have with the clock is that I can see it in preview mode, but whenever I schedule it to a display it does not display. My layout is correct (I have a check mark in Layouts and Designer) and everything else shows up when scheduled, just not the time and date. Could this be related to the above issue?
Yes, running 1.7.8. Clean installed it two days ago. Digital clock module with [DD/MM/YYYY] [HH:mm]. I have tried it with text too, but same result. Analog module displays fine.
I solved the issue. The duration of the clock was set to 100000000 seconds for some reason, which caused it not to display. I set it to a more reasonable 30 seconds and it is working.
The date was formatted DD/MM/YYYY, and I wasn’t paying attention. I switched it to MM/DD/YYYY (the way everyone is used to reading it) and it actually is displaying the correct date and time. Apologies for my ignorance.
