Probleme superposed layout - windows
Hi, I’m new in xibo and I like it, I have a problem with the layout superposition, the first layout play video and when the second layout superposed start, the first layout restart and it’s same when the superposed layout finish the first layout restart … sorry for my bad english
Can you confirm that by superposition/superposed, you are referring to Overlay Layouts? If you are using an Overlay with a Windows Player, it may explain the issue.
If you can export the 2 Layouts and provide a me link where I can download them, I can test them on my setup. I would recommend sending me the link in a private message.
thank you for reply, yes i 'm using Windows Player and yes it’s about Overlay Layouts !! when the second overlay layout begin playing the first layout restart and it’s same when the second overlay layout finish the first layout restart, so what should I send you ?
when my overlay layout play, my vidéo in the first layout restart and at the end of the overlay layout my first layout restart ( my defaut layout video of 3 min my overlay layout : 5 second )
If you can send me both Layouts, I will replicate the schedule on my Player.
You will need to export the Layouts in the Layouts section on your CMS. You can do this by clicking on the down facing arrow at the end of the Layout and choose Export from the menu. The Layout will then export as a zip file.
You will then need to upload those Layouts and provide me with a link so I can download them and test them on my setup. I would recommend sending me the link on a private message.
If you are unable to upload the file, please let me know.
many Thanks.
Thank’s for reply i’ve a problem with my server for export my layout , otherwise for testing overlay layout i’ve two layout : first layout 1media music video in (1980 *1080 ) 3 min ; second layout one picture (1980 *1080 ) : 5 second , i would like to insert my picture on overlay layout every minute whithout restart my first layout music video and cut it
