I have created a layout that utilizes the Ticker module however, the ticker is not rotating through the items in the RSS file. Rather the ticker displays the number of items per page set in the format and does not transition to the next page or pages. Since this problem started on a test server I was developing a custom reader module on (running 1.8.2) I went ahead and set up a test environment running 1.8.3 on Ubuntu LTS and am using a clean Windows VM for displaying the layout. Unfortunately, the problem continues in the test environment.
For testing, I am using http://rss.cnn.com/rss/cnn_topstories.rss for the RSS feed and I am running on 1.8.3. I have also tried https://vtnews.vt.edu/feeds/research/_jcr_content/content/list.xml as an alternative RSS feed with the same results. For settings, I have the duration set to 5 seconds per item, number of items set to 100, items per page to 5 and items taken from the start of the page.
Thoughts?
