hi
i have problem with Ticker and i can not load any rss content in my layout…(not load in layout preview)
is there any special configuration?
thanks a lot.
Perhaps cURL is the problem? Using Tickers, Forecast, Twitter and other external resources that make use of HTTPS connections
Thanks dear Peter for answer;
i think cURL doesn’t have problem …because ForecastIO API works correctly.
Can I have a link to your feed please?
My test RSS link: Sample Feed - Favorite RSS Related Software & Resources
screenshots of my configurations:
Thank you.
So, feed is valid, although there are some recommendations https://validator.w3.org/feed/check.cgi?url=http%3A%2F%2Fwww.feedforall.com%2Fsample-feed.xml
Seems to be working fine on our test CMS.
Could you enable debugging (on Report Fault page), try to load the rss feed again and then see if there are any errors on Logs page?
here is log of client:
https://www.photobox.co.uk/my/photo/full?photo_id=9072039409
Just in case, could you please click ‘verify all’ from Modules page in CMS?
Do you use any kind of proxy that could interfere with connection to this rss feed?
Could you perhaps try bbc feed - http://feeds.bbci.co.uk/news/rss.xml
and see if you encounter the same problem?
i verified all modules!
unfortunately the RSS link is blocked by my Country Policies!!!
no i dont have any proxy…
Do you test my RSS link in your CMS? (i mean http://www.feedforall.com/sample-feed.xml )
a Suggestion!
could you please give me a Layout(export) with correct RSS Region (tested by you) and i try to Import the Layout to check if i encounter the problem?
then i can trace what is my problem? Server, Proxy, Design and …
Thanks alot Peter.
