Hello, I have created a region with ticker layout using the background color of opacity 0.3. I works perfectly in preview but not on windows client. The CMS is installed in Linux Server.
please help
Can you confirm what version of the Xibo for Windows Player you using?
Can you also confirm if you are using a background image with your Layout? If you can provide me a download link to the exported Layout, I would be happy to take a closer look for you.
The weather widget is also having the same problem, not showing the background color with opacity 0.3
The Xibo for windows Player version is 10.8.10.0
Here’s the exported layout link
https://drive.google.com/file/d/1I1ihnz7nThB4FxCgstZkG6Hm2v03Msxw/view?usp=sharing
Thank in advance
