Here’s my result from test url
"entries": [
"wifi": "GuestAP",
"rows": {
"tglAwal": "7 Mei 2018",
"tglAkhir": "13 Mei 2018",
"password": "WifiPass100"
"number": 1,
"processed": [
"Tanggal Awal": "tglAwal",
"Tanggal Akhir": "7 Mei 2018"
"Tanggal Awal": "tglAkhir",
"Tanggal Akhir": "13 Mei 2018"
"Tanggal Awal": "password",
"Tanggal Akhir": "WifiPass100"
"messages": [
"Processing 1 results into 3 potential columns",
"Processing Result with Data Root rows",
"DataRoot is an object",
"Processing as Multiple Rows",
"Processing tglAwal",
"Processing tglAkhir",
"Processing password",
"Consolidating entries",
"There are 3 entries in total"
I have tried to make Data root to rows but still the fetch was not as expected.
I expect that the dataset return only 1 row, but as you can see, it was processed to 3 rows.
DId i miss something here?
Still no luck so far, i couldn’t make it right.
Here’s my dataset column setting
I think i already put it right for the column data setting.
One more thing, i also tried to catch the credential username and password using $_POST , but the array is empty.
So how do i catch those variables?
My CMS is v.1.8.9 using docker.
caro
May 17, 2018, 12:14pm
3
Hello!
If I understood correctly, your JSON will understand 2 colomns only : one with “tglAwal”, “tglAkhir” and “password” and another with “7 Mei 2018”, “13 Mei 2018” and “WifiPass100”.
Like this example : Data Set -> Remote data source
If you want 3 colomns, perhaps the JSON will be rather :
“wifi”: “GuestAP”,
“rows”: [
{“tglAwal”: “7 Mei 2018”},
{“tglAkhir”: “13 Mei 2018”},
{“password”: “WifiPass100”}
And to edit Colomn, in Remote Data Path you should write juste tglAwal, tglAkhir or password.
I don’t know if it’s what you want, but it’s like this that I successed.
Peter
May 17, 2018, 12:46pm
4
Indeed json in that format might not be correctly understood there.
You could have it as an array like here Remote Dataset - Trouble configuring Remote Data Path
so say something like this in json.
"wifi": "GuestAP",
"rows":[
"tglAwal": "15 Mei 2018",
"tglAkhir": "23 Mei 2018",
"password": "WifiPass122"
3 columns with the remote data path corresponding to the names in .json ie
tglAwal, tglAkhir and password for your 3 columns.
data root in dataset would be rows as well as in the other example and the processed data should be
"processed": [
I tried again, and this time i copied the example JSON above and compress it using jsonlint ,
here’s the result
Then i try to call it using postman :
I think, so far so good, then i try to recreate the DataSet :
But then when i try to test the data url , here’s the result :
Here’s the complete response from xibo :
"entries": [
"wifi": "GuestAP",
"rows": [
"number": 1,
"processed": [
"messages": [
"DataRoot is an array",
"Processing 0",
"Processing 1",
"There are 2 entries in total"
Any idea , did i miss something here?
Peter
May 17, 2018, 2:31pm
6
The remote data path is incorrect.
As I mentioned it should be tglAwal, tglAkhir, password instead of what you currently have ie 0,1,2
Ahh yes, thank you, i just missed that point,
Don’t know why i put those numbers, maybe i missed read something that i have to put relative number there.
Thank you Peter, it solved now…
pak riopangeran apakah masalah datasetnya sudah beres?? mohon info nya dunk…
