My problem is that I cant force my layouts to smoothly refresh (simultaneously all region) between each region.
In my layout prices are separate regions that use the ticker connected to data-set. The main problem with asynchronous refreshing is shown in the video.
Xibo does not currently support synchronised Layouts/Regions. Xibo will also need time to load the next media item on your Layout, causing the brief delay you are seeing. My apologies for any inconvenience this may cause.
