Problem in the currency widget.
The widget is not locating the image “currency_USD.svg”
I searched the installation folder and could not find the file in any location.
Occurs in CMS 1.8.11.
To solve the problem I had to go to:
“xibo / modules / currencies / currency-flags /”
Copy the file “USD.svg” to
“xibo / web / media /”
And rename the file to: “currency_USD.svg”
Should not this be done automatically?
Existe varias maneiras de você puxar ou inserir as imagens.
Se for possível me passa o fonte (URL) para dar uma olhada que passarei a melhor solução.
