Hi
Spun up a Windows 2012 R2 lab VM and installed Xibo 1.8.1 successfully. Added a new disk and mounted it to D:\Library and gave IUSR modify rights to this folder. Went into Xibo and changed Administration -> Settings -> Configuration -> Library Location from D:\xibo-cms-1.81\library\ to D:\Library\. Once I’d refreshed the web console I got the following configuration error:
Problem copying provided file into the Library Folder
Checking both folders shows that D:\Library\ is identical to D:\xibo-cms-1.81\library\ apart from D:\Library\ does not contain the fonts.css file. I’ve tried copying the file, but get the same error.
Have I missed something?
Tony
