Something sounds like it just is not getting setup correctly.
What version of XAMPP are you using? What os is on the live server?
Hi
@theaor I didn’t read this whole topic before I sent my reply to your ticket, so I was unaware that Colin already tried a lot of things to solve this issue.
So when you make a copy of layout created by the system it’s fine but when you make a new layout from your account something is wrong. That points us to the server configuration/settings/permissions issue. I hope that together you, Colin and we (Spring Signage) will be able to solve it.
For the sake of clarity, this is what I understand from reading the ticket:
From your comments so far I am assuming you won’t be too phased by using the Developer Tools in your browser? The preview kicks out a lot of console logging that might help us narrow down the problem. Would it be possible for you to capture this console logging and paste it in this thread?
Just:
Thanks,
Dan
Hey Dan! I am re-visiting this issue as we’ve decided to try this again. My apologies in my very-delayed reply, we were pulled away on another project. So we’ve setup a new install on a windows VPS server, with the same results. Any help with this would be greatly appreciated! This is what console displays:
html-preview.js:374 Uncaught TypeError: Cannot read property ‘id’ of undefined
self.nextMedia @ html-preview.js:374
self.run @ html-preview.js:381
self.run @ html-preview.js:214
EventEmitter.emit @ html5Preloader.js:127
html5Preloader.loadCallback @ html5Preloader.js:383
(anonymous function) @ html5Preloader.js:232
onready @ html5Preloader.js:248
Hello there i may find out what is going on with that error.
I had it right now and fixed it,
If you look at your layouts listing you may notice that there is a cross on the status of the layout ( that’s what i got )
its means that your layout have an error and cant be displayed.
for me it was because i had an empty region that broke all of it.
you may look into that and see if something wrong is going with one of your region and you may have forgot to delete the empty region that spawn when you create a layout.
I hope that’s will fix your problem
(sorry for the bad english french here)
Best regard,
tommy
