alex i have also read one of your solution in which you said that
the xibo player only download file once in a day .what does that mean
i understand that xibo player download files once in a day if i want to download twice then it will give error
am I right?
Verify all is, as Alex said in '15 on Modules page in CMS not layouts page.
That Alex’s post you’ve quoted was about something entirely different ie wrong setting for download window start/end time in display profile.
By default this is set to 00:00 and 00:00 which means it’s always open and player will download any required files when it needs to - after it will check in with CMS, in 1.7 series it will do that each collection interval, which is a setting also in display profile.
You probably should not search for solutions from '15 that are regarding specific issues not directly related to the one you’re having - unless you also modified the download window start/end time in a odd way.
Can I see a screenshot of status window on your device when the issue occurs please?
Is the default layout assigned to your display valid?
Layout id 4 is set as default layout for your display and said layout seems to be invalid according to your player status window.
What to do now then.
You can either change the default layout for your display to a layout that’s valid.
Displays page -> Edit display -> Default Layout
Or you can fix whatever is wrong with layout id 4, since it’s not on the list, it might be retired perhaps - you can check that on Layouts page -> Filter change Retired to Yes
You do not get any errors there right now, it’s just the info logs, at a guess you have the display profile assigned to the player with higher than ‘error’ log level - in any case those are not errors, it should display layout id 17 just fine now.
