PreLoad Calendar View
Dear Community,
I have a Layout with 10 different ICS Calendar Views to create a room booking overview.
Technically it is working well. Only it takes a while until page have been loaded - understandable with 10 different ICS files to get processed.
Is there a chance to pre-load layout in the background and show page when loaded? While page is loading, last layout should be displayed.
Is this already possible?
And if not, can we add this as a feature request?
Best
Daniel
Which version of the player application are you using? We do preload some widgets already, but perhaps that is not the case for calendar. @maurofmf
