PowerPoint duration is always 10s
I’m on the 14 day cloud trial. So far so good. Got PowerPoint working on a Windows display. Followed the excellent instructions and added the registry edits.
I’m trying to create a layout with some text, and a PowerPoint slide show. When I insert the PPT widget, it defaults to 10s. The slide show is actually 27s. I then try to edit the duration using the Set A Duration checkbox. I set it to 27s. Click save. The duration reverts to 10s. No matter what I do I always get 10s.
What am I doing wrong?
Version 2.0.1
Thanks,
Sean
Interesting, could you send me a private message with your CMS name in our Cloud Hosting please?
I will take a look at it for you.
Thank you for the details, I had a look at the layout and the code, I can see why it does not work correctly.
We will get that fixed in 2.0.2.
Thank you for bringing this to our attention
When should I expect to see 2.0.2?
Thank you for your message. Version 2.0.2 is in development, there is not a set release date currently. Any news regarding its release will be posted on the Xibo Blog:
