The home folder only helps users put content in the right place - with folders disabled you know that a user will always add content to their Home folder whenever they do anything.
As an admin you will still be able to see folders (in a new folders page) and set sharing as necessary.
For a simple Group A → Users 1 and 2 scenario, you would create Folder A which you share with Group A and set as home for Users 1 and 2. All new content added by Users 1 or 2 automatically goes in Folder A, and both users have access to it.
If their second group had a different folder, you could set that folder to also be shared with them. When folders are disabled the content would all appear in the same list, same as if you select “All folders” with folders enabled.
For example:
- Group A and Group B
- User 1 is in Group A and Group B
In v2 the new content would have been shared individually with both groups (assuming group view/edit/delete in settings).
In v3 the new content goes in Folder A (the home of User 1), which is shared with Group A and Group B.
Yeah, we have lots of multi-select things on our list - i’ll note down your suggestions.
Perhaps a global option for this is the simplest solution for you, Patrick and anyone else wanting a super simple set up. All sharing is managed by dropping users in and out of groups. I’ll discuss this option with the team and see if its viable.
I am not familiar with your setup beyond multiple restaurants per campus - but I have worked with an organisation using Xibo in similar circumstances. Folders allowed them to adopt a system where a user only belongs to one user group.
They have:
- a folder per restaurant
- all “single restaurant users” in the same group
- a group for support staff that have access to all restaurants folders (these are only in a group called “support staff”)
In their situation they trust users not to use the root folder (they trained them to select the right folder one time and then collapse the menu). But with the above change we will be able to set home folders appropriately and disable the folders feature for the “single restaurant users” group.
The support staff are trained to pick the right folder when working with a restaurant. The org also have other folders for “National” and “Regional” content, shared with the right groups.
This may not be useful at all in your situation, but I thought it worth mentioning in case.
