Hello!
We have two televisions that are right next to each other (side by side). We want to be able to use them to play the same video at the EXACT same time. Is that possible with Xibo? The audio would need to be in sync.
Xibo does not support synchronised content. If you are using 2 separate Xibo Players, they will become slightly out of sync with each other over a long enough period of time.
You mentioned that the 2 Displays are next to each other. A possible solution would be to use one Xibo Player but connect both TVs to it using a signal splitter. Because both Displays will be receiving the same source, they will both display the content at the same time.
