Player Tizen - transition between videos
Hi, I’m new to Xibo and I’m testing with Xibo community and Tizen player. I was able to load the videos on the screen, but there’s a black jump between each video. It’s not a continuous loop. What’s the reason for this?
Hi Raul, welcome to Xibo! The black jump between media is normal in the current version of Xibo because it’s not designed for seamless looping.
To minimize the issue, you could try creating longer layouts/playlists/videos so they don’t loop as frequently. This way the black transitions will occur less often.
You might also want to check out this post:
and this one from JerryW:
