2.3.7 docker with nginx proxy for SSL stripping
Android
2 R203
I’m having the “Player is missing dependencies” message in my player. It doesn’t load configured layouts.
I have tried the “Verify all” fix in modules page and cleaning cache, but that did not help. I also enabled auditing and tested using cloud CMS 2.3.7. The cloud CMS worked correctly and after pointing the client back to our local CMS I got the following log-messages:
| 884226 | 67809ec | 2020-11-06 14:14 | XMDS | POST | INFO | Kornet-Fb | NotifyStatus | PDO stats: { “default”: { “select”: 4, “update”: 1 }, “log”: { “insert”: 3 }, “isolated”: { “update”: 1 }, “length”: 0.11354899406433105 }. |
| 884225 | 67809ec | 2020-11-06 14:14 | XMDS | POST | DEBUG | Kornet-Fb | NotifyStatus | {“totalSpace”:13922910208,“availableSpace”:13626785792,“height”:1080,“deviceName”:“012345678912345”,“packageName”:“uk.org.xibo.client”,“width”:1920,“applicationName”:“Xibo”} |
| 884224 | 67809ec | 2020-11-06 14:14 | XMDS | POST | DEBUG | Kornet-Fb | NotifyStatus | Testing whether this display is auditing. 1604872800 vs 1604664898. |
| 884223 | 67809ec | 2020-11-06 14:14 | XMDS | POST | DEBUG | Kornet-Fb | NotifyStatus | Checking permissions against the logged in user: ID: 1, Name: system, UserType: 1 |
| 884222 | ae439de | 2020-11-06 14:14 | XMDS | POST | INFO | Kornet-Fb | MediaInventory | PDO stats: { “default”: { “select”: 4 }, “log”: { “insert”: 4 }, “isolated”: { “update”: 5 }, “length”: 0.3903019428253174 }. |
| 884221 | a7433ac | 2020-11-06 14:14 | XMDS | POST | INFO | Kornet-Fb | MediaInventory | PDO stats: { “default”: { “select”: 4 }, “log”: { “insert”: 4 }, “isolated”: { “update”: 2 }, “length”: 0.368333101272583 }. |
| 884220 | 6a14a48 | 2020-11-06 14:14 | XMDS | POST | INFO | Kornet-Fb | MediaInventory | PDO stats: { “default”: { “select”: 4 }, “log”: { “insert”: 4 }, “isolated”: { “update”: 2 }, “length”: 0.37961888313293457 }. |
| 884219 | a7433ac | 2020-11-06 14:14 | XMDS | POST | DEBUG | Kornet-Fb | MediaInventory | Media Inventory status changed to 2 |
| 884218 | ae439de | 2020-11-06 14:14 | XMDS | POST | DEBUG | Kornet-Fb | MediaInventory | Media Inventory status changed to 2 |
| 884217 | 6a14a48 | 2020-11-06 14:14 | XMDS | POST | DEBUG | Kornet-Fb | MediaInventory | Media Inventory status changed to 2 |
| 884216 | 6a14a48 | 2020-11-06 14:14 | XMDS | POST | DEBUG | Kornet-Fb | MediaInventory | |
| 884215 | a7433ac | 2020-11-06 14:14 | XMDS | POST | DEBUG | Kornet-Fb | MediaInventory | |
| 884214 | ae439de | 2020-11-06 14:14 | XMDS | POST | DEBUG | Kornet-Fb | MediaInventory |
