Having issue when turnoff tv or unplug HDMI cable.
My resolution is 1280x720, when I turned off monitor, the resolution became 1024x768. After changing the registy, as you told here:https://community.xibo.org.uk/t/windows-player-screen-doesnt-scale-after-display-resolution-increase/15415/6
After registry change It always 1280x720 even turned on/off monitor
But xibo still understands when tv off, it restarts the layout but screen size is same. After turn on tv, xibo restarts the layout again but the video size not fits the screen anymore.
Here is screenshot:
Now as an another solution you provided in comminty, trying giving static size from CMS-Display Settings-Display Profile. Looks working fine on my first try, will try checking, let you know if working.
I think xibo wont try resizing on windows resolution change, it only looks for resolution on player start.
Or After resolution change the app should restart itself, not just restarting layout.
If you have solution please inform me.
Michael
