Hi, is it possible to set permissions on layouts allowing only view policy avoiding modifications?
We need to diplay region allowing only double click to modify timelines.
Bye and thanks.
Massimo.
Bye and thanks.
Massimo.
No, unfortunately no.
The only way to give a user access to layout designer is to give him the edit permissions to the layout - and with that he will be able to add new regions change existing ones etc.
With view only permissions, user won’t be able to access layout designer to make any changes.
