I have got docker ce installed. I found and pulled a xibo image on the OMV docker repo and I can run it. It creates a container that can be started but I can’t see anymore instructions anywhere after that!
Can anyone help?
EDIT: Sorted it. Just used putty install via commands. Then had a 10 minute wait for it to configure.
