Hi. I have just installed Xibo for the very first time, both the CMS and the player. I’ve been playing around with it a little and all looks great, but I can’t seem to make it display the contents on the extended desktop. Are there any novice level tutorials or getting started guides that explain how to do that? I am using a TV via HDMI, but Xibo displays only on my monitor. Please help a noob.
Perhaps this topic will help you:
Thanks for your reply. My problem is that Windows identifies the TV connected to the HDMI port as 1, and my monitor connected to DVI as 2, and no resolutions alchemy seems to work for me. Both displays have the same resolution (1920x1080), if I set the origin to 0,0 the player displays on the monitor, if I set it to 1920,0 it does the same.
Ok, you can disregard this, reinstalling the client solved the problem.
This topic was automatically closed after 2 hours. New replies are no longer allowed.
