Hello everyone,
I have a recurring problem in planning a layout, in fact, when a user plans an invalid layout, but makes it valid after planning, then I have the XIBO test pattern which appears with a TTL of 86400 (24 h). Well, when I look for the layout, well it no longer exists, its number has changed. The only way to get the flow back on track is to delete the data locally on the player, redo the integration on the XIBO server and voila! that works. Does anyone else have this user experience?
Fred
