My Layout if a little bit too big for my screen
I use 2 monitors with 2 clients that are displaying webpages.
My first client got Best Fit for its layouts. My second client got Open Natively.
Now here comes my problem if i wanna set my second client also too Best Fit and restart the client it says Webpage not found. And if i use Open Natively it is fine but its a little bit too big. For both my first and second client i use the same type of webpage.
Can someone help me with this problem.
Kind Regard,
I’m not sure why would it work only on one of the players in this case, it does not seem like the webpage itself is preventing your from changing the iframe dimensions if you can get that on one player - assuming it is exactly the same webpage of course.
Is it available over the internet or is internal site?
It’s a internal site using PHP
Edit: if i use best fit i can see the webpage shown correctly for less than 1 minute and then it says Webpage not found. On the second screen.
I solved the problem. The solution was that in Displays -> Edit -> Advanced -> Display was still on Windows that was the profile of the first screen, soo i changed it too the second screen and it is working fine for already 30 minutes.
Thank you for the help with changing embed port because that help allot :smiley:
Kind Regards,
