Hi I have a proble width twitter module
I create the api key and the other key in twitter and put into module.
add a Region.
Edit timeline and I check “Override the template?” and add the tag [Photo]
In preview Only appear the text. I can’t see the images. the profile and the images/gif on the tweet.
Any idea?
thanks!!
1 17-02-21 08:16:51 CMS module getimagesize() [function.getimagesize]: Read error!
8
Notice
/home/velvet/public_html/Panel/modules/image.module.php
215
2 17-02-21 08:16:51 CMS module filesize() [function.filesize]: stat failed for theme/default/img/forms/filenotfound.png
2
Warning
/home/velvet/public_html/Panel/lib/modules/module.class.php
2255
3 17-02-21 08:16:51 CMS module finfo::file(theme/default/img/forms/filenotfound.png) [finfo.file]: failed to open stream: No such file or directory
2
Warning
2264
4 17-02-21 08:16:51 CMS module ob_end_clean() [ref.outcontrol]: failed to delete buffer. No buffer to delete
8
Notice
2288
5 17-02-21 08:16:51 CMS module readfile(theme/default/img/forms/filenotfound.png) [function.readfile]: failed to open stream: No such file or directory
2
Warning
2289
6 17-02-21 08:16:52 CMS module getimagesize() [function.getimagesize]: Read error!
8
Notice
215
7 17-02-21 08:16:52 CMS module getimagesize() [function.getimagesize]: Read error!
8
Notice
215
8 17-02-21 08:16:52 CMS module getimagesize() [function.getimagesize]: Read error!
8
Notice
215
9 17-02-21 08:16:52 CMS module getimagesize() [function.getimagesize]: Read error!
8
Notice
215
10 17-02-21 08:16:52 CMS module filesize() [function.filesize]: stat failed for theme/default/img/forms/filenotfound.png
2
Warning
2255
11 17-02-21 08:16:52 CMS module filesize() [function.filesize]: stat failed for theme/default/img/forms/filenotfound.png
2
Warning
2255
12 17-02-21 08:16:52 CMS module getimagesize() [function.getimagesize]: Read error!
8
Notice
215
13 17-02-21 08:16:52 CMS module filesize() [function.filesize]: stat failed for theme/default/img/forms/filenotfound.png
2
Warning
2255
14 17-02-21 08:16:52 CMS module filesize() [function.filesize]: stat failed for theme/default/img/forms/filenotfound.png
2
Warning
2255
15 17-02-21 08:16:52 CMS module finfo::file(theme/default/img/forms/filenotfound.png) [finfo.file]: failed to open stream: No such file or directory
2
Warning
2264
16 17-02-21 08:16:52 CMS module finfo::file(theme/default/img/forms/filenotfound.png) [finfo.file]: failed to open stream: No such file or directory
2
Warning
2264
17 17-02-21 08:16:52 CMS module filesize() [function.filesize]: stat failed for theme/default/img/forms/filenotfound.png
2
Warning
2255
18 17-02-21 08:16:52 CMS module finfo::file(theme/default/img/forms/filenotfound.png) [finfo.file]: failed to open stream: No such file or directory
2
Warning
2264
19 17-02-21 08:16:52 CMS module ob_end_clean() [ref.outcontrol]: failed to delete buffer. No buffer to delete
8
Notice
2288
20 17-02-21 08:16:52 CMS module finfo::file(theme/default/img/forms/filenotfound.png) [finfo.file]: failed to open stream: No such file or directory
2
Warning
2264
21 17-02-21 08:16:52 CMS module ob_end_clean() [ref.outcontrol]: failed to delete buffer. No buffer to delete
8
Notice
2288
22 17-02-21 08:16:52 CMS module finfo::file(theme/default/img/forms/filenotfound.png) [finfo.file]: failed to open stream: No such file or directory
2
Warning
2264
23 17-02-21 08:16:52 CMS module readfile(theme/default/img/forms/filenotfound.png) [function.readfile]: failed to open stream: No such file or directory
2
Warning
2289
24 17-02-21 08:16:52 CMS module readfile(theme/default/img/forms/filenotfound.png) [function.readfile]: failed to open stream: No such file or directory
2
Warning
2289
25 17-02-21 08:16:52 CMS module ob_end_clean() [ref.outcontrol]: failed to delete buffer. No buffer to delete
8
Notice
2288
26 17-02-21 08:16:52 CMS module ob_end_clean() [ref.outcontrol]: failed to delete buffer. No buffer to delete
8
Notice
2288
27 17-02-21 08:16:52 CMS module ob_end_clean() [ref.outcontrol]: failed to delete buffer. No buffer to delete
8
Notice
2288
28 17-02-21 08:16:52 CMS module readfile(theme/default/img/forms/filenotfound.png) [function.readfile]: failed to open stream: No such file or directory
2
Warning
2289
29 17-02-21 08:16:52 CMS module readfile(theme/default/img/forms/filenotfound.png) [function.readfile]: failed to open stream: No such file or directory
2
Warning
2289
30 17-02-21 08:16:52 CMS module readfile(theme/default/img/forms/filenotfound.png) [function.readfile]: failed to open stream: No such file or directory
2
Warning
2289
31 17-02-21 08:17:12 CMS module getimagesize() [function.getimagesize]: Read error!
8
Notice
215
32 17-02-21 08:17:12 CMS module filesize() [function.filesize]: stat failed for theme/default/img/forms/filenotfound.png
2
Warning
2255
33 17-02-21 08:17:12 CMS module finfo::file(theme/default/img/forms/filenotfound.png) [finfo.file]: failed to open stream: No such file or directory
2
Warning
2264
34 17-02-21 08:17:12 CMS module ob_end_clean() [ref.outcontrol]: failed to delete buffer. No buffer to delete
8
Notice
2288
35 17-02-21 08:17:12 CMS module readfile(theme/default/img/forms/filenotfound.png) [function.readfile]: failed to open stream: No such file or directory
2
Warning
2289
36 17-02-21 08:17:12 CMS module getimagesize() [function.getimagesize]: Read error!
8
Notice
215
37 17-02-21 08:17:12 CMS module getimagesize() [function.getimagesize]: Read error!
8
Notice
215
38 17-02-21 08:17:12 CMS module filesize() [function.filesize]: stat failed for theme/default/img/forms/filenotfound.png
2
Warning
2255
1 - 38 / 38 (38)
