Missing xibo-player.options in 4.0.9
yes
Xibo 4.0.9 on Ubuntu 24.04.5
I have Xibo 4.0.9 installed on Ubuntu 24.04.5, but it does not run xibo-player.options. Error message is: Cannot find application options in xibo-player.
Last time I checket the beta channel (4.0.6?) it was fine! Can you help?
Best Regards,
Lonxi
Try launching it in the Terminal using xibp-player. If you get an error message, please post it here
A problem with version 4.0.9 and Ubuntu 24.04 and 26.04 has already been reported here: Linux Player - Beta 4.0.9 - Sept. 7 - Developer Experience / Linux Beta Testers - Xibo Community
Thank you, problem is solved in 4.0.10
