Hi, I had the error where I could not get past the installation page during to icons being missing. I have applied the workaround however I get missing icons within Xibo itself. Anyone know how to resolve this please?
ONeill
March 21, 2019, 1:39pm
2
I have the same problem after upgrading to version 2.0.0.
alex
March 22, 2019, 12:19pm
3
Are you running Xibo inside a folder?
ie http://example.org/xibo
If so, its likely this issue:
I’m using CentOS LAMP server with Xibo and did an upgrade to 2.0.0.
Everything went quite well except getting fontawesome to work. I could not see the status of my displays etc because of the missing font. My Xibo installation is under /xibo in default website. I have activated “RewriteBase /xibo” in .htaccess file in web folder as always when I upgrade.
[Screenshot]
My quick solution was to copy the “dist” folder from xibo to the root of default website.
How can this be done correctly?
Ma…
ONeill
March 23, 2019, 2:47pm
4
Yes, this fixed my problem with icons.
Copying folder “dist” from “\xibo\web” to web server root (outside “xibo” folder).
I now have all icons in Xibo 2.0.0.
