Hello
Having an issue getting back up and running after a computer reboot, in the past after a reboot I would manually restart the CMS containers as stated in the documentation. This time that is not working, all of the user’s, layouts and displays are gone. I have rebooted the computer that is running the CMS again and run the “docker-compose stop” and start commands again and still no luck. I looked in the directory “C:\Xibo\shared\cms\library” and all of our content is still there, It just doesn’t show up when logging into the web portal. Any ideas would be appreciated. The CMS running on windows 10 using Docker.
Try stopping the containers, then go in to the Docker settings, unshare the C: drive, and then share it again.
Then start the containers.
Worked like a charm. Thanks
