Docker Version 4.3.1
The popup thumbnails for media items is very small. It’s not possible to even read the text on the image. Is there a way to change the size of the thumbnails? See attached screenshot.
Thanks in advance.
Could you check what the screenshot size is configured to?
You can find this setting under Settings → Displays → Display Screenshot Default Size
It’s set to 400. The screenshot thumbnails are fine. This is just an issue with the popup thumbnails for the media items.
Hi, we are aware of this and will be addressing this in a future release.
Thank you for posting!
