Hello there.
First of all, great job to the Xibo team, this CMS is really awesome and full of amazing features !
I just have a little question about the media library location.
I searched across topics and I didn’t find the answer.
I want to install my Xibo on a distant server, while having my media library on a local server. The thing is, I use the Docker Installation (and I’m still making test), and I didn’t run into some kind of assistant installation.
I was thinking about changing the yml files at the installation to change the library location, but I saw that the medias are put in the same place as the libraries needed for Xibo, so I’m not sure it’s a good idea.
So, is there a way to put just the media library outside of the Xibo files now ?
Also, is it possible to have multiple library servers (without them being connected between each others) ?
Thank you,
Mehdi.
