Can you manually slide through images on a tablet? Example: If I wanted to create a dessert menu for a restaurant, I don’t want it to automatically slide through the desserts but the user can swipe the screen to checkout the desserts manually.
Xibo doesn’t support interactive signs yet, but we’re talking about what that might look like here:
It would be good to add your use case to that thread.
For now you could get what you need with an embedded HTML region with your own Javascript to handle sliding through the images. Have a look at the random Slideshow guide as a basis:
