Looking for Animated Radar map
I’m new to Xibo. Where can I find an animated weather radar map widget?
There is no such widget, it might be possible to embed html code in embedded widget, if you have access to such view.
I used Accuweather and just grabbed the Image for the radar I wanted.
For example
How did you get the code for the image? When I go to accuweather, I don’t get the same URL when copying the image link.
I’m not overly familiar with AccuWeather, but I assume to they do provide a way to embed their widgets.
Assuming they do provide embed code (as an iframe or similar) for such widgets, then you can put that in embedded widget in Xibo to show it.
