Login Screen Screen Saver
Sorry if this has been asked before… I did google some remarks in other threads, but it did not seem to lead to anything.
To recap … I want to run the Xibo as the screen saver on the login screen of a windows PC.
It does not seem hard to set up a normal screen saver on the login screen (3D aside?).
But when I install it as a screen saver on my login, I have to re-do the settings via the screen saver.
Where are these settings stored … so I can clone them for a screens saver that I can move to the default user.
TIA
Peter
Hi Peter
Sorry for the delay in getting back to you. Settings are stored in the %AppData% folder in a file called XiboClient.config.xml
