I can not log in using the xibo_admin account. I have tried that user name with the password I set up in the config.env file and continue to get a username and password incorrect error. I have also tried the FAQ solution to reset the password and I continue to get a Syntax error near unexpected token `(’
Solved. I did not try logging in with password as password, being that I got the syntax error. I was able to login with xibo_admin/password.
