Log with tons of deserialize tags, commands
Version 4.3.1
Android
Android 407
I’ve got tons of such logs for all Android devices:
160544 2a0354d 2025-10-14 16:50:59 PLAYER POST ERROR X1 Configuration deserialiseCommands: unable to deserialize commands, e = class com.google.common.reflect.TypeToken isn’t parameterized
160543 2a0354d 2025-10-14 16:50:59 PLAYER POST ERROR X1 Configuration deserialiseTags: unable to deserialize tags, e = class com.google.common.reflect.TypeToken isn’t parameterized
Classified as an error?
What does it means?
How to solve the problem?
Thank you for reporting the issue, we have fixed this in the Android Player App v4 R408 which is currently under QA and should be released soon.
The error is caused by an update to an underlying library and causes Commands and Display Tags not to be set correctly, leading to them not functioning.
