I would like to add a webpage which is updated by the company very often. I inserted it in the timeline, but in the preview I cannot see the updates, instead I see the webpage without content.
Is there a solution for that?
What’s the webpage’s URL? (so we can test it)
Does it looks the same on the players?
for windows client, make sure you have IE 11 installed, and Xibo for Windows 1.7.8.
If it’s frequently updated, you might want to also have a look here Webpage updating issue
Hello Peter!!
I’ve just tried on the player. It looks OK! When I previewed it did not
update itself but player works very well. Thanks :))
Great, I’m glad it works for you now
